Empower 1 software
Posted: Wed Jul 03, 2013 8:21 pm
by fibonacci
Is it just me or does anyone else find it horrifically difficult to use because of a terrible user interface. Is it worth it to upgrade to the latest version of Empower?
Re: Empower 1 software
Posted: Thu Jul 04, 2013 2:17 am
by DR
It just takes some getting used to. You have to go all the way to Empower 3 to get any significant interface improvements, and I have some doubts that you would call them significant...
Posted: Thu Jul 04, 2013 5:58 pm
by Karen01
I find the Empower UI very powerful and easy to use (I always use pro mode)... In any case The Empower 3 UI is pretty much the same as Empower 1 (and Millenium for that matter)
Posted: Fri Jul 05, 2013 3:44 am
by bundy5686
It really depended on your personal preference. I found that Empower is much more organized than Chemstation.
Posted: Fri Jul 05, 2013 9:50 am
by mattmullaney
I'm afraid that I agree with DR, Karen01 and bundy5686...I've used Waters software from ExpertEase through Empower 3, Dionex software from PeakNet 4 through Chromeleon 6.80, more flavors of ChemStation than I can easily recall, Perkin Elmer Turbo- and TotalChrom and Thermo ChromQuest 4.0 and 5.0.
But Heck, it doesn't matter a whole lot which of these I like...if you, fibonacci, find the Empower interface "horrifically difficult to use because of a terrible user interface", then Why On Earth consider purchasing Empower 3 at all?
Rest assured, the Empower 3 user interface hasn't changed all that much from the early 2000s until now.
Posted: Fri Jul 05, 2013 1:15 pm
by Karen01
I used ExpertEase back in the early/mid 1990's ... i liked that too!
- Karen
Posted: Fri Jul 05, 2013 6:13 pm
by tom jupille
A client once summed it up this way: "Data systems are kind of like religions; the one you started off with always seems to be the best / most logical."
Posted: Sat Jul 06, 2013 12:23 pm
by Meerkat
Well for what it's worth, I was "raised" on Chemstation Agilent, then was thrust into a lab where Empower Build was used. I can certainly say that initially I did NOT find Empower to be as "user-intuitive" as Chemstation was--now having been a user of it for a while I find that Empower Build is OK. Guess it's like Tom said, depends on what you were reared on and that determines your bias (to paraphrase).
Posted: Mon Jul 22, 2013 5:37 pm
by remesquaddie
If you are collecting data from a any detector [ almost ], other than a Waters PDA, you can use something which is much easier and very much cheaper than Empower called CLARITY, by DATAAPEX. You can download a demo version ahead so you can get a feel for it ahead of purchasing.
Posted: Tue Jul 23, 2013 6:58 pm
by JGK
At my last company we had empower 1 and Chemstation. Every analyst in the place hated chemstation but loved the empower.
