In addition, I am using an internal standard and I need to monitor the response. I need to be within ±50% recovery of the average response in my ICAL.
If anyone has insight into how I can monitor these performance checks, it will be greatly appreciated. Ideally, I would like the software to generate some type of report showing the calculated ratios and internal standard responses along with qualifiers on a result that is not within compliance.
Thanks!
