SPE and HPLC of Amines
Posted: Thu Jul 28, 2005 9:24 am
I am trying to replicate an assay for amines found in equine faeces from a paper by SR Bailey et al. (Research in Veterinary Science 74 (2003) 113-118) but am having problems getting the standards to run reproducibly.
The amines are first dissolved in water (or acetone) and derivatised with dansyl chloride. They are then extratced using C18 cartridges and eluted with acetonitrile and filtered. I am looking at concentrations in the range of 0.1 ug/ml up to 20 ug/ml. Heptylamine is used as an internal standard at a concentration of 5ug/ml.
The HPLC is fitted with a Discovery C18 column and a Discovery C18 supelguard column. Solvent A is 5% acetonitrile in water and B is acetonitrile. The gradient elution is 25% B at the start increasing to 45% B at 5 minutes, 60% B at 10 minutes and 70% B at 15 minutes. It is then held isocratically for another 15 minutes. A flow rate of 0.7ml/min is used and UV detection at 250nm.
The problem I have is that I don't seem to get the same peaks twice! If I run a sample containing a mix of 6 amines I get 6 peaks, but if I run the amines individually I don't get single peaks that correspond to those in the mixed sample! Also the peaks seem to move randomly. I noticed that some of the peaks seemed to be coming off very close to the end of the run so I then did longer runs of 60 minutes. I am also heating the column to 60degC (as this was suggested by another amine paper).
Can anyone spot what I am doing wrong? I'm a bit concerned that if I can't get the standards to run reproducibly there will be no point even trying to run samples from the horses! I'm not sure if the problem is with the SPE or the HPLC.
Any suggestions would be most appreciated!
Best Wishes,
Frosty
Best Wishes,
Frosty
