HPLC Problems
Posted: Tue Jun 25, 2013 8:45 pm
We've been running HPLC, and have lately been experiencing some issues. It all started when we forgot to have the DAD UV lamp on at the beginning of a run, and hastily turned in on. The trial was not a success, with no peaks being observed. We attributed this to the DAD not being on from the beginning. However, since this run, we have been unable to observe any substantial peaks that were, up until this point, consistently present. Even more issues have started in the last two runs we've done. Upon running some blanks to make sure they are flat, the baseline suddenly drops to around -2000 about 20 minutes into the run. This has not happened before. Does anyone know what might be causing this? We did a self test on the DAD, and it passed everything except the Spectral Flatness test. From what I could tell, this means there is too much noise, but as we can't seem to be getting any sizable peaks at all, I suspect this may not be an issue. We've also made sure that general setting (ie, wavelength, etc) have not been changed.
