Residual acetic acid determination in API
Posted: Mon Jun 17, 2013 7:51 am
by Pawan kumar
Dear Friends,
hi,
I have to develop a method to determine the acetic acid in AIP which is insoluble in water.
We have will known method for water soluble API by HPLC.
When i tried other diluent in place of water,response of acetic acid is very poor and not a perfect peak obtained.
I also tried the the same work on GC,but not achived the result.
Pl. share your experiance.
Pawan kumar
Re: Residual acetic acid determination in API
Posted: Mon Jun 17, 2013 10:11 pm
by MestizoJoe
Hi Pawan,
If you can dissolve it in 80% acetonitrile try using a HILLIC method.
Just google "acetic acid by hillic" for a good starting point.
Posted: Mon Jun 24, 2013 7:17 pm
by HippyLabRat
HILIC only needs one "L"
Searches work best when the spelling is correct! ;)
Posted: Mon Jun 24, 2013 8:09 pm
by MestizoJoe
Haha that's true. Google usually asks me if I meant something else.
Posted: Tue Jul 23, 2013 5:11 pm
by Grimibo
You can try to extract AcOH with water and then test clear supernatant.
