Can I use HCl in mobile phase for LC-MS analysis?
Posted: Sun Jun 16, 2013 10:33 pm
by Claire
I know when the acidic modifier is needed in the mobile phase for LC-MS analysis, the acidic modifier has to be volatile. Since pure HCl is gas at room temperature, can I use hydrochloric acid in the mobile phase for the LC-MS analysis? Thank you.
Re: Can I use HCl in mobile phase for LC-MS analysis?
Posted: Tue Jun 18, 2013 10:28 am
by lmh
I personally wouldn't dare, and certainly not without consulting the manufacturer of the instrument (not forgetting the LC as well as the MS). Do you really need that strong an acid?
Posted: Thu Jun 20, 2013 3:50 pm
by James_Ball
Formic Acid is what is most commonly used for an acid modifier as it is also volatile. Acetic Acid can be used also. Mineral acids such as HCl and HNO3 would be very corrosive to the metal parts in the MS I would think.
