Failed General Leak Test - Dionex 3000
Posted: Sat Jun 15, 2013 9:19 am
I am running on a dionex ultimate 3000 and have been noticing some inverse "shark fin" peaks in my baseline. Initially I thought bad seals or a bad connection. So I ran a "general leak test" to try to see the leak in my system. None was found, but my system still failed the test. The test started around 440 bar and dropped to about 340 bar in the 5 min. So I replaced the seals and am still getting a failing result with approximately the same value.
I do notice a large amount of precipitate on the face of the outlet unit. That is the weird part, because I don't believe any solutions should be near that specific area. The face is only electrical to my knowledge.
All help and ideas are appreciated, and thanks in advance for your assistance.
Tim
Tim
