TotalChrom error during run setup
Posted: Fri Jun 14, 2013 3:49 pm
by katebigge
I am working with a re-installation of TotalChrom workstation v6.3. I am preparing for validation, but I cannot setup a run. When I try to setup from a sequence, I get the following error: -995 Couldn't open seqfile. Is this a file permissions issue? I have tried a new sequence and a previously-used. Same error every time.
Re: TotalChrom error during run setup
Posted: Mon Jun 17, 2013 5:48 am
by Muhammad Akbar Khan
Hi, Kate,
It indicates that some set up file are missing, so needs to contact with service statation, they only can solve the problem.
Take care
Bye
Posted: Mon Jun 17, 2013 12:49 pm
by katebigge
To close this topic, I will post the resolution. This was a file permissions issue. After consulting with Perkin Elmer, I asked our IT to re-check the permissions matrix established during the install. There were errors. Fixing the file permissions issues solved the problem
