Assistance Needed On Calculating Hydrogen Gas Volume
Posted: Sun Jun 09, 2013 3:09 am
Dear all and respective expert,
Good days to everyone! Hope everyone are doing great!
I'm conducting watersplitting reaction to generate hydrogen. The H2 gas generated after 1 hour reaction will be cumulated at headspace (volume headspace = 10ml) and the H2 gas will be transferred into online-GC by using peristaltic pump for quantification.
The sample loop volume of GC is 1ml and the measured-hydrogen concentration in that 1ml sample loop after calibrate with known-standard gas is 100ppm. Can I determine the “TOTAL AMOUNT OF H2 GAS GENERATED IN 10ml HEADSPACE” in such a way (which is proportional):
TOTAL AMOUNT OF H2 GAS GENERATED IN 10ml HEADSPACE = 10ml x 100ppm / 1ml
P/s corrects me if I’m no correct.
Hopefully anyone of you can shed a light on this base on your expertise.
Jeff Ooi
Jeff Ooi
