Why Nitrogen as sheath gas ?
Posted: Fri Jun 07, 2013 8:43 am
by shadowcand
Hello
I would like to ask you a question.
Why is the Nitrogen used as sheath gas? Why not Argon or Helium ?
Thank you.
Re: Why Nitrogen as sheath gas ?
Posted: Fri Jun 07, 2013 10:50 am
by CE Instruments
Helium is most unsuitable. Far too light to act as a sheath and expensive compared to Nitrogen. Argon might work but again with the volumes used Nitrogen must be the best choice ?
Posted: Fri Jun 07, 2013 11:05 am
by shadowcand
Thank you for information.
Posted: Thu Jul 04, 2013 4:12 am
by mckrause
Argon actually works better than nitrogen. Found this out by running out of nitrogen one day, had to steal the argon tank from the ICP. Nitrogen is cheaper by far, and works adequately.
