ECD oxidation
Posted: Sun Jun 02, 2013 8:54 am
by Hiz
We are running an SRI GC in combination with an automated chamber system in field. Today I noticed both carrier and make up gas cylinders were empty while GC was still running. Does this mean ECD has been oxidized for sure? If yes, is there a chance it might still be usable or it has to be replaced now? Sorry if this topic has been discussed before.
Hiz
Re: ECD oxidation
Posted: Mon Jun 03, 2013 2:54 am
by chromatographer1
There is only one true way to determine this.
best wishes,
Re: ECD oxidation
Posted: Mon Jun 03, 2013 4:21 am
by Hiz
Hi Rod,
I've run the system and visually it seems OK; i.e. all N2O and O2 peaks appearing as they should. Not sure if I need to run any sensitivity tests. If yes, how?
Hiz
Re: ECD oxidation
Posted: Mon Jun 03, 2013 11:17 am
by Don_Hilton
I assume you run a low standard every now and again to confirm sensitivity?
