Help!!! Low recovery with QuEChERS [urgent]
Posted: Thu May 30, 2013 3:20 pm
Hi everyone,
I am recently playing with QuECHERS for OP pesticides. The recovery is quite bad.
I am wondering if I did anything wrong or having poor technique of QuEChERS method.
I scale down the material because of limitation of instruments (e.g. I can only use 15mL Centrifuge tube)
Here are the producers of my QuEChERS method:
1. 5 mL DI water as blank into 15 mL CT. Spike 1 ppm mixed standard.
2. 5 mL 1% acetic acid in ACN is added, then shake it with 30 seconds.
3. Salt mixture of 2g MgSO4 and 0.5g sodium acetate is added, I.S. of dichlorvos-d8 is added,
4. Then shake it with 30 seconds.
5. Centrifuge with 3800 rpm for 3 mins. (centrifuge speed is maximized)
6. 2 mL organic layer is transferred to dSPE tube. (without GCB, wondering if I should replace it with activated carbon or not in order to remove pigment)
7. Shake it then centrifuge with 3800 rpm for 3 mins.
8. Dilute the solution for LC-MSMS analysis.
I guess I have no problem in the LC-MSMS (Waters instrument) part because the internal calibration give r^2 more and less 0.99.
Are there anything I need to pay attention with?
By the way, the d-SPE CT contain 900mg MgSO4, 150 mg PSA and 150mg C18.
Please kindly reply if you have any idea. Thank you so much ><
