GC/MS with chemstation
Posted: Wed May 15, 2013 4:15 pm
by cody841
Are there any good tutorials out there for this software? I come from Empower and Galaxie and I can't stand this software. Looks like it can do a lot for sure, but really hard to learn!
I just want to print a good old system suit report that summarizes RSDs from each of my 8 peaks and also displays resolutions etc. Even with the manuals I seem to be having trouble, and this is unusual because I usually pick up software pretty quick!
Re: GC/MS with chemstation
Posted: Thu Oct 24, 2013 7:52 pm
by ChemLane
Sorry I know this is an old post. I am having the same issue with Chemstation, it is not very intuitive like Empower is. Did you ever figure out how to get a System Suitability Report with multiple injections?
Posted: Fri Oct 25, 2013 12:42 pm
by rb6banjo
It's amazing what perspective gives. I "cut my teeth" on Chemstation so I can't stand Empower (I have a Waters HPLC). I love the Agilent system!
I am sorry, but I don't use the system suitability part of the software. I presume you've read the manual but in case you haven't:
http://www.chem.agilent.com/Library/use ... anding.pdf
It may be helpful to you. SS is discussed in Chapter 11.
Posted: Fri Oct 25, 2013 2:14 pm
by nimbi63
Set up a sequence with your system suitability runs, In Sequence > Sequence Output (or in the newer software, Sequence > Sequence Parameters and select the Sequence Output tab) select Print Sequence Summary Report. Select 'Setup', choose what you want in the system suitability report (usually statistics on calib. runs). Under the extended statistics tab you can set limits. There are good help screens for each step.
