HPLC run of caffeine non-buffered
Posted: Wed May 15, 2013 3:08 pm
by MikeT
Hi guys,
I want to just run a test-run on a UHPLC with mobile phase 100% H2O. I only have NaH2PO4 dihydrate and 0.1 M HCl in the lab, with no pH meter...with this, I am hesitant about making a buffer, so I want to run the caffeine w/out buffer. Since its a test run I don't care about the quality of my peak/or peaks. Just wanted to know if this would hurt the machine. I will start with making probably a 10 to 50 mM solution. Thanks a lot guys.
Re: HPLC run of caffeine non-buffered
Posted: Wed May 15, 2013 4:15 pm
by skunked_once
You will need 40-60% methanol to get a reasonable elution time for caffeine on a C-18 column. You can just add 1% acetic acid to the mixture instead of messing with a buffer.
Posted: Thu May 16, 2013 6:43 am
by HPLCaddict
Do you want to run with or without column? What are you trying to accomplish by this test run?
Posted: Thu May 16, 2013 8:18 am
by aceto_81
We run our caffeine method on plain water-methanol, without buffer, so no worries about messing around with buffers/acetic acid/....
Posted: Thu May 16, 2013 2:32 pm
by MikeT
thanks guys. I just want to get a hang on using the HPLC... My background is in theoretical chem. but unfortunately I only have a Master's degree and most jobs for computational chem require Ph.D. But they say if you are theoretical then you can do analytical, but not the other way around.
Posted: Fri May 17, 2013 7:07 pm
by skunked_once
That's interesting. I'm an analytical chemist but many of my experiments begin with the comment "Theoretically, this should work."
