importing signals into chemstation
Posted: Sun May 12, 2013 12:33 am
I have an Agilent 6890 coupled to a Spectral Analysis DiscoverIR. The GC is programmed by Openlabs Chemstation for GC (version C.05 I think). The IR data is recorded using Grams software.
I've exported the Max S/N traces from the Grams software and saved them using the AIA file format.
I've also saved Chemstation data files using Oven Temperature as a signal.
I have a custom Chemstation macro which uses the PlotChrom command to print the chromatogram of the loaded signal. (I believe it uses the Chromres register to do so) The macro also prints important header and barcode information that I require.
I would like to replace the Oven Temperature signal in my chemstation data files with the Max S/N trace exported from Grams in order to use my custom macro.
Does anyone know how to do this?
