Need help from Thermo ISQ users
Posted: Wed May 08, 2013 8:13 pm
I need help from Thermo ISQ users. I am using a Thermo Scientific ISQ. The default tune for the 69 ion is 20 million counts. This cause the multiplier to run at a high voltage and I have to change two multipliers in a year.
I have no idea why the default setting is so high. It seems to me that the abundance have nothing to do with signal to noise. I am now tuning the 69 ion down to 9 million counts, which cause the gain to set to 1E5 instead of around 3E5, and I still have about the same sensitivity.
I don't want to miss anything, so if you are a Thermo ISQ user, and you know of any reason why I should set my gain higher, please let me know.
Thank you so much.
chromuser2000
Thank you so much.
chromuser2000
