Using salt instead of acids or buffers in mobile phase
Posted: Fri May 03, 2013 1:05 am
I want to ask if anyone has had success using mobile phases with salt as the additive instead of acids or buffers.
For a current application there is a reason that I want to avoid anything with acid/base characteristics. I know that cations like K+ can be an alternative way to mediate silanol interactions. I have read publications on this type of thing over the years. However, I cannot currently get my hands on any actual examples.
So I am wondering: has anyone tried anything like this. For example, using of 20 mM KCl as the mobile phase additive (just as one might use 20 mM ammonium acetate).
(by the way: for this application we do not need a volatile mobile phase and we do not need very high organic - so no concern with salt solubility)
Thanks very much.
Thanks very much.
