problem about knowledge LC MS
Posted: Tue Apr 30, 2013 12:15 pm
I have two questions about this topic:
1. In GC MS, the internal standare often is used ( I think the IS is used to control the sample extraction and the injection sample to GC column), but in LC MS (or LC DAD), the IS rarely is used (if the IS is used, it is often isotope of sample, not a substance that is the same as GC MS). Why? If I want to use IS in LC/MS and I do not have isotope of sample, how can I do?
2. In ESI LC MS, I known about mechanism that is used to explain negative and positive mode, but in APCI and APPI LC MS, I don't know about the mechanism forming negative mode. Will someone help me?
