Quality Graphics from Chemstation software?
Posted: Fri Apr 26, 2013 2:08 pm
by msengine5
Is there any way to get press quality graphics of MSD chemstation chromatograms?
Re: Quality Graphics from Chemstation software?
Posted: Fri Apr 26, 2013 2:25 pm
by Peter Apps
Export the raw data to Excel or something else that can do plotting, and then plot signal vs time. Beware this gives very big graphics files.
Posted: Fri Apr 26, 2013 5:56 pm
by KM-USA
1. Screen captures
2. Print, then use a scanner
Posted: Sun Apr 28, 2013 11:59 am
by dblux_
Could you please define your expectations (what do you mean by press quality) ?
Posted: Mon Apr 29, 2013 7:11 pm
by Yama001
The "Clip windownumber" command puts a copy of the graphics window into the clip board - from there it may be pasted where ever you like. The quality may be debatable.
Posted: Tue Apr 30, 2013 11:18 am
by lmh
I'm with Peter Apps on this; for publication-quality chromatograms I've never found any better approach on either LC or GC chemstation. When you consider the hard work you've done in making the analysis, you may as well show it at its best rather than hideously pixelated with distorted bad lettering.
Posted: Tue Apr 30, 2013 3:05 pm
by nimbi63
You didn't mention the revision of ChemStation, but you can convert the graphics to a Windows Meta File, which is high quality graphics. We do that for publication all the time with GC and LC ChemStation.
Not sure on MSD ChemStation, but GC, LC, and LCMS, on the install disk is a \UCL subdirectory, browse to \UCL\LC_UCL and open folder 5. It should have 'Tools.mac'. If not, you have an older version, so search for the folder with Tools.mac.
Copy all files EXCEPT Readme.txt to C:\Chem32\Core or C:\HPChem\Core. In ChemStation, on the command line enter: Macro Tools.mac
OK the disclaimer and you have a new menu - Tools. Load your chromatogram, click on the Chromatogram window, then select Graphics > Window to Windows MetaFile, and name the file. The WMF file is high quality graphics which can be used for publication.
