Pharmacopoeial Methods
Off-topic conversations and chit-chat.
It is my understanding that if using a pharmacopeia method in a cGMP environment it is enough to verify the method and there is no need to validate the method, was I advice correctly? The methods used to test raw materials are all from pharmacopeia and these raw material are used for manufacturing, do we need to validate the methods? Please advice
You are referencing USP <1226> Verification of Compendial Procedures. A quick Google search should help.
thank you!
Just do not miss the detail that you have to document that you have verified that it is suiteble for the intended use.
Izaak Kolthoff: “Theory guides, experiment decides.”
Thank you Krikos
In total there are 30 users online :: 1 registered, 0 hidden and 29 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 29 guests
