LC-MSMS No signal? [Solved]
Posted: Mon Apr 22, 2013 4:38 am
Hi everyone, I'm playing with waters TQ detector for pesticide analysis.
I washed the column with 50% ACN to 90% ACN overnight and somehow there is now no analyte peaks.
I tried for many types of standard, and only background noise can be obtained.
Then, I checked the flow rate for washing column, and it is 0.5 ml/min. I am not sure if it is too high, cause I found there is a little solution leak from the top of probe sometime. ( Wondering if it is really a leakage, maybe I can take a photo if it comes again...)
I also used tune page with high selective analyte but again no signal observed.
What can I do to fix this up? I really need your respond or I will be beyond schedule. Thank you.
