If you had $10k to spend on an HPLC...
Posted: Fri Apr 19, 2013 12:37 am
...would you buy a new, but very basic BLC-10 from Buck Scientific or an old, refurbished HP 1050?
I am looking to obtain an HPLC to be used by undergraduate students, mostly in 2nd year organic and analytical chemistry labs. Being at a small undergraduate liberal arts college means that I don't have a lot of money available to spend (unfortunately). I also don't have much practical experience with HPLC to base my decision on. Hence, I am posing this question to the forum. Based on the research I've done, and quotes received, I feel like my options at this point are between:
(1) a BLC-10 from Buck Scientific. This is specifically designed to be low-cost and meant for educational purposes. It is about as basic as it gets: isocratic elution and single wavelength (254 nm) detection, operated with (free) PeakSimple software. There is an option to have exchangeable filters to detect at other wavelengths (280, 365, 420, 505, 540 nm.. would these be worth it?) The fact that it is new is attractive, as well as that it has a very small footprint, and there is far less that can go wrong with it. It would probably suit my purposes and expose my students to the basics of HPLC. But...
(2) a refurbished 1050 system from HP would have very appealing features (quaternary pump, solvent degassing, variable or multi-wavelength detection, autosampling, etc), but these systems are ~20 years old. Would it be foolish to buy such an old system or are these 1050 systems reliable enough? Compared to the BLC-10, I suspect there is far more that could go wrong with it, especially given the age. There does seem to be a fair number of 1050 modules on the refurbished equipment market should I ever need to replace a module.
I would appreciate anybody's thoughts on this dilemma (or other suggestions!)
Thanks in advance!
Darren
Thanks in advance!
Darren
