At first sight, the collector seemed to use the GSIOC command set, but by analysing the communications protocol between the Mass Lynx software and the machine, I realized that it uses quite different commands.
Basic operation of the collector (Valve on/off, Go to position x/y, Home) is no problem, but I would like to get full control over the machine, i.e. setting all of the parameters from a remote PC instead of working my way through the option menus.
At this point, I am not quite sure if the options are at all accessible through a serial connection. It seems PC control is limited to very basic functionality, but it would be highly interesting to read out e.g. actual position/vial number and drop count.
My final goal is to create a simple LabView Application that is able to control the collector.
If anyone can provide me with a list of recognized commands, I would highly appreciate.
