Varian Saturn 2000, High signal at all masses
Posted: Sat Apr 13, 2013 10:42 pm
Hi, from some time i have a problem with my saturn 2000.
I'm not able to make it work because it read an enormous signal at all masses.
I need to make a mass calibration but i can't do it because also with the "cal gas" valve completely closed the flow of "cal gas" is read as too much.
I think that can be something shorted inside the instrument because if you move the unit the signal goes down and it remain low for about 15-20 seconds, after that the signal return as the beginning.
How can I find my short circuit?
Have I to think of another kind of problem?
What can I do for fix my instrument?
Sorry for my bad english but i'm italian
Thank you
Enrico
Thank you
Enrico
