Retention index database
Posted: Fri Jul 15, 2005 7:52 pm
by Suresh Seethapathy
Dear fellow chromatographers,
I have been trying to procure a copy of "The Sadtler Standard Gas Chromatography Retention Index Library" but have been unable to find a source yet. I would appreciate any references or information regarding that book and also would welcome any suggestion to find retention index data for huge group of compounds with various stationary phases.
Suresh
Posted: Fri Jul 15, 2005 10:35 pm
by tom jupille
Sadtler is owned by BioRad. If you haven't already tried there, check
http://www.biorad.com
Retention index library
Posted: Sat Jul 16, 2005 7:50 pm
Thanks for your reply Tom. I'd try BIORAD, they don't seem to have it anymore i guess. Any other source? (for the same volume or any other such library?)
Suresh
Posted: Sat Jul 16, 2005 11:52 pm
by tom jupille
I did a quick search of various used-book sites to no avail. Best bet might be to contact Sadtler (BioRad) directly and see if they can either point you in the right direction, or perhaps find an old copy holding up table leg.
Posted: Sun Jul 17, 2005 2:16 am
by Russ
Bio-rad became Digilab which was recently bought by Varian. Don't know where Sadtler wound up, but you might check with Varian.
Retention index
Posted: Mon Jul 18, 2005 9:28 am
by chromgraph
Suresh,
I don't know whether you have accesed Supleco site. There you can find the technical literature you are looking for. Bulletin number 880 will definitely help you. If you don't get,send me your email i will forward a pdf copy of that bulletin.
nedughatj
Posted: Mon Jul 18, 2005 2:19 pm
Hi Tom,
I contacted bio-rad and they were not able to help me as it went out of publication a long time back! perhaps more than 10 years back!
Russ, I guess Sadtler is still handled by BIO-RAD informatics. I don't know if they have merged with Varian and still have a dedicated website for Bio-rad.
Chromgraph, thanks for the supelco technical bulletin, I wasn't exactly looking for the stuff it had, but it gave me some terrific info which i might be able to use in my research work! Thanks a ton.
Thanks all for replying. Any more ideas would be really appreciated!
Suresh
