RRT: relative retention time
Posted: Thu Mar 28, 2013 1:29 pm
I did try to search the archives but found it is not easy.
Recently, I try to copy a HPLC testing performed in oversee lab. I found all peaks were shifting, which was very common(about 1 min). We are using the identical columns and all the same related conditions: C18, 250x4.6x5, 1ml/min, 0.1TFA in water (A) and in ACN(B), gradient, column 35 C, etc.
We also found some peaks had very similar RRT such 0.84 to 0.85; but other could have 0.14 difference: meaning 1.45 vs 1.59.
Does any one summarize, in theory, when RRT should be comparable and when not? How close is considered to be "similar' or " comparable"?
Jim
Jim
