MASSTransit interpretting RT wrong
Posted: Wed Mar 20, 2013 4:16 pm
If anyone out there using MASS Transit could help with this it would be helpful. Having issues converting Thermo .RAW files to HP Chemstation files. MASS Transit keeps changing the retention time to seconds instead of minutes. Its like it is not reading the .RAW file correctly. When I open a chemstation file in MASS Transit it has the correct retention times, its only with the .RAW files.
