Individual results into one result set in Empower 2
Posted: Thu Mar 14, 2013 3:08 pm
Hi all,
I am using Empower 2 and I want to quantitate reinjected QCs used for extract stability using the original cal curves. This means that I have cal curves in one run (sample set) and ES samples in another run (another sample set). Our LIMS software imports result sets...not individual results. Therefore, I need to somehow combine the individual injections or results into only one result set so I can import it. How do I do this?
Thanks!
-Micky
Thanks!
-Micky
