GC MSMS, HPLC slection
Posted: Tue Mar 12, 2013 11:12 am
by Bhavesh Sojitra
We are planning to buy following equipments
GC QQQ (Options: Bruker , Agilent)
ICP_OES (Options: teledyne Leeman Labs Prodigy XP, Agilent 710, Thermo i CAP6500)
HPLC (Options: Agilent 1260, Shimadzu LC2010)
UV-vis (Options: Agilent, Perkin)
FTIR (Opions: Agilent Cary 630, Bruker Alpha, Thermo Nicolet)
GC with ECD,FPD & FID (Bruker, Agilent, Thermo)
Kindly suggest right supplier with right Equipment models
Re: GC MSMS, HPLC slection
Posted: Tue Mar 12, 2013 7:02 pm
by JGK
Bavesh,
Rather than getting a lot of meaningless recommendations from members who aren't in your part of the world it would be better if you conducted your own evaluation.
Evaluate the suppliers on fixed criteria for service and repair. generate some samples and in your presence have the instrument set up and analyze it.
Comparing different machines analyzing the same material will give you an idea of how easy/hard instrument operation is. Also you should have a lot of probing questions to ask with regard to serving, breakdown response and resolution.
You are looking at a major equipment investment and should satisfy yourself that your choice is the correct one.
Going off a vague recommendation from the internet is not a plan for success
Posted: Tue Mar 12, 2013 9:14 pm
by James_Ball
JGK is correct with trying them out and looking for service response in your area.
I can though say that we have had good luck with our Thermo iCAP6300 which is very similar to the 6500. Very rugged and very small footprint compared to most others.
