Chemstation Reporting Question Very Urgent
Posted: Mon Mar 04, 2013 11:23 am
by Leni
i seem to have to following issue when trying to generate reports in Chemstation: when i have more than one signal(overlayed signals) and try to generate a report, an error message appears, saying that it is not possible to print report if there are overlayed signals. Is there a way to create my own custom reports in wich this would be possible? I don't need anything fancy, just some basic information about methods, sequence, injection and sample in the header, stacked chromatograms and a result table with areas, retention times, resolution between peaks, maybe (if possible) RSD for peak areas.
Can this be done? Thank you in advance.
Lenard
EDIT: also another question: i started creating a report, but i can't add the "Acquisition Method Date" & Time ...of when it was last saved.Please help!
EDIT 2: i there also a way to modify the report for the method (when in "Print Method...") to add some things to the header and footer?
Re: Chemstation Reporting Question Very Urgent
Posted: Tue Mar 12, 2013 12:26 pm
by Leni
NOBODY?! :( :cry: :(
