Negative ghost peaks
Posted: Mon Jul 11, 2005 12:45 pm
I am running a GPC system for the analysis of different polymers and had no problems in the past. However, a few days ago I observed ghost peaks in my chromatograms. All the ghost peaks are negative and following a regular peak. The shape of each ghost peak is quite similar to the previous regular peak.
My chromatographic conditions:
·Mobile Phase: Tetrahydrofuran (stabilised with 0,025% Butylhydroxytoluol)
·Stationary Phase: 4 Columns, 300 x 7,5 mm with pore sizes of 100 Å, 500 Å, 10E3 Å and 10E4 Å
·Detector: Refractive Index
·Flow rate: 1 ml/min
·Temperature: 30°C
·All samples are solved in THF (mobile phase)
Does anyone have an idea of what is the source of my problem?
Thank you in advance!
Tina
·Temperature: 30°C
Tina
