Accuracy for Method Validation of fatty acids
Posted: Wed Feb 27, 2013 10:13 pm
Does anyone know what the acceptance criteria is for accuracy of fatty acids such DHA and EPA? I am using a combination of the AOCS Ce 1i-07 and AOCS Ce 1b-89.
I am spiking my placebo samples (soybean oil) with a known amount of standard (Eicosapentanoic methyl ester and/or Docosapentanoic methyl ester), then performing the same sample prep steps as I would a regular sample (base then acid catalysis to methylate triglycerides and any free fatty acids).
My calculated DHA and EPA amount is more than the known amount I spiked into the sample. I am getting around 22-24% difference from the true value for each of the 3 concentrations I created. Plotting Peak Area vs. Amount of Standard (mg/g), my R^2 = 0.9999. I have tried spiking the placebo sample after it has been weighed and also spiking the test tube before sample is weighed and drying with nitrogen (proved a little bit better but not by much. Percent difference from true value= 16.9%) . There is some systematic error occuring. I have created newly prepared standards and ISTD solutions as well.
