Installing an HP 7694 headspace on a 6890 GC with S/SL inlet
Posted: Fri Feb 22, 2013 3:03 pm
I would like to install a HP7694 Headspace on a 6890 GC with S/SL inlet and it's the first time i will use an headspace. So, i need some help please.
The HP7694 is not a standalone version, I should use the GC EPC flow module to control the gaz flow and the gaz pressure. It is a G1289A headspace sampler.
If i have right, i need to connect the carrier gaz:
-Connect my gaz tank in the rear of my GC, in the EPC inlet
-Cut the carrier gaz line just before the split splitless inlet
-Connect a zero dead volume union on my carrier gaz line, and attached it with a new 1/16 tubing in the rear of the headspace.
-Connect a zero dead union on my transfer line and attached my transfer line with the rest of the small tube I cut previously, just before the split/splitless inlet
I am right?
How to connect the pressurization gaz? Directly attached at my gaz tank?
I read something about a auxiliary EPC module, i don't know if i need use it, and how to use it.
Need I change everithing on my S/SL inlet like the septum nut or the liner? I read the better liner for headspace analysis is a 2mm internal diameter.
Your help will be highly appreciated, because i don't want to pay an agilent service to install the headspace.
Thanks a lot!
Pierre
I am right?
Thanks a lot!
Pierre
