Column washing
Posted: Fri Feb 15, 2013 2:45 pm
Hi everyone.
I've been wondering about how to best clean a C18 LC-column and thought I'd like to hear what you think about the way I'm used to do.
Generally, cleaning instruction as I'm used to say to clean column using mobile phase were buffer (if used) is replaced with water then go to 100 % organic and then store it in 100 % organic. Most of the time when I wasn't as used to cleaning procedures, I just cleaned column with low organic, then changed mobile phase and then flushed the column with 100 % organic for storage.
However, ever since I had major issues with columns being dirty, I started using a gradient going from 10-100 % organic with great results. Ever since, I've used this method for cleaning columns and haven't had the same problems as before. I always think this way gives better possibilities to rinse the column of a broader range of impurities/dirt.
What do you think is the best way to clean a column? Is anyone else doing as I'm doing? Is this procedure a good way to keep the columns in good shape?
Regards
/Pär
Regards
/Pär
