Controlling Chemstation via external Visual Basic code
Posted: Thu Feb 14, 2013 7:06 pm
Hey,
I'm setting up a system to control my Chemstation B.04.01 via an external script which could be in any language. I've seen in Agilent literature that DDE commands would be able to do this, but I can't find any examples where they do this. I also found one example for their UV-VIS chemstation where they directly access the command line in Chemstation externally, but could not get it to work. I just need to be able to execute a macro in Chemstation using external code in visual basic, C++, C#, etc.
Any help would be greatly appreciated, thanks!
David
EDIT: Here's the example I found:
http://www.chem.agilent.com/Library/tec ... 683616.pdf
David
