About a GC column
Posted: Wed Feb 06, 2013 9:29 am
I will use the following column, but i can not find which mark and model is the best choice. Is it packed column or capillary column? If you know, can you help me about it ?
Stationary phase : diatomaceous earth for gas chromatography R impregnated with 10-20 % of poly(dimethyl)(75)(diphenyl)(25)siloxane R (film thickness : 125-150 µm)
L: 1.8-3 m ve Ɵ =3-4 mm
Thank you for your helps
