Ion Pair Reagent Concentration Question
Posted: Tue Feb 05, 2013 6:13 am
Hi I am noticing some odd things when using Tetrabutylammonium Hydrogen Sulfate when separating a phosphonate.
At 5mM at pH 7.1, I am noticing high peak tailing (1.5). I tried using a 10mM concentration at pH 7.1 (Both buffered with 5 mM Ammonium Phosphate). I am seeing the peak with short equilibration/saturation of column, but gradually over time, the peak becomes very broad with high tailing and low sensitivity.
So, how does the concentration of IPReagent affect peak sensitivity? I was under the impression that, generally, smaller IPReagents require a higher concentration than if I were to use a bigger one. Could it be the high ionic strength buffer than is causing a problem? What is the best way to buffer in IPC?
Would there be a better IPReagent in this particular case? Maybe something that isn't so strong? n-pentylamine or diethylamine?
