Peak on isocratic mode when injection the eluent
Posted: Mon Feb 04, 2013 2:23 pm
Hello everyone
I use an isocratic method (MeOH/water 65/36, pre-mixed and degassed in ultrasonic bath) over a Phenomenex Luna C18 column. As blank I always inject 20 µl of the eluent. What I did not expect but find reproducibly is a peak at about 2.6 min. First I thout the autosampler was defective because this peak coelutes with air injected from an empty vial (this was a coincidence I found this out).
But this peak occurs on different machines (Agilent 1100, two different Dionex systems), and with different batches of the eluent. Therefore I do not believe in the air hypothesis any more. I cannot believe that three different autosamplers are defective. Also I only see this when running the MeOH/water method.
Any idea what this peak could be?
Thank you,
Jörg
PS.: This peak appears regardless of MeOH/ratio (I tried 45/55 to 75/25).
Thank you,
Jörg
