How to reduce noise in LC/MSMS???
Posted: Mon Jan 28, 2013 1:52 pm
I would like to know what can I do to reduce the noise in LC/MSMS, the noise level is quite high and signal to noise ratio is around 7 to 9.
I am doing analysis on PAHs (Fluorene, Anthracene, Fluoranthene and Pyrene.)
Instrument used are Waters UPLC and TQ detector.
Column is BEH C18 with 1.7 micrometer.
Solvent is 66% ACN : 34%water
Flow rate is 0.3 mL/min
I tried to increase the flow rate and solvent composition, it only vary the shape and retention time of peaks and the noise is still so high
By the way, I would also like to know why the baseline of chromatogram is sometime drift, I found it better after several sample flows... Are there any good reasons to explain this???
Please help me!! Thank you all.
