GC for Organic solvent
Posted: Mon Jan 28, 2013 7:24 am
by lauric
Can someone teach me how to set the method to seperate the IPA and Ethanol by using HP-Innowax??
Re: GC for Organic solvent
Posted: Mon Jan 28, 2013 7:49 am
by dblux_
I doubt this column could sufficiently resolve IPA from ethanol (especially if one of them is solvent).
Would try DB-1.
Posted: Mon Jan 28, 2013 8:42 am
by lauric
I just joint at solvent distribution and repacking company one week, the GC is mainly use to test the mixed solvent that may content ACETONE, BUTYL ACETATE, BUTYL CELLOSOLVE, CELLOSOLVE ACETATE, ETHYL ACETATE, HEXANE, ISO-BUTANOL, IPA, MIBK, MEK, METHANOL, N-BUTANOL, TOLUENE, XYLENE, DEA, DEG, MPG, MEA, MEG, MPA, TEG, ETHOXY PROPANOL, AMYL ACETATE,DIMETHYL FORMAMIRY,CYCLOHEXANE.
I do not sure the HPInnowax is suffient to test this or not and currently i do not have DB-1.
Anyone here can tell me more specify what column should i use and what setting do i need to use.
Posted: Mon Jan 28, 2013 9:18 am
by dblux_
...I do not sure the HPInnowax is suffient to test this or not and currently i do not have DB-1.
Take 1st chromatography supplies catalog of your choice. There are always several existing aplications. Look for "industrial solvents" and start with most appriopriate application. Then you may modify it to better suit your needs.
Posted: Mon Jan 28, 2013 9:48 am
by lauric
I have done this for one week, i cant find any column that consist of IPA and Ethanol at the same time. If there is no present either one of this solvent, the results shown all ok......
Posted: Mon Jan 28, 2013 10:26 am
by dblux_
Posted: Mon Jan 28, 2013 11:08 am
by lauric
http://content.yudu.com/Library/A1qs9z/AgilentGCSelectionGu/resources/69.htm
page 69
I will contact column supplier for more info
Posted: Mon Jan 28, 2013 11:20 am
by dblux_
My pleasure.
You mean price and discounts ? :D
BTW - you will probably choose narrower column than 0.53 mm.
Posted: Mon Jan 28, 2013 2:46 pm
by Johnny Rod
I was also going to suggest a DB-624, this phase handles most common solvents very well. I wouldn't use a DB-1 for solvents, the more polar stuff chromatographs badly.
Posted: Mon Jan 28, 2013 3:12 pm
by chromatographer1
Johnny's comments are worth heeding.
IPA and Ethanol separate well on the 624 - 1301 phase column.
and of course, so do many other solvents.
If you expect to separate high % levels of both and the 1301 doesn't suffice, then there is always the porous polymer columns which work wonders.
best wishes,
Posted: Mon Jan 28, 2013 3:26 pm
by dblux_
In 1st post there were only IPA and EtOH to resolve and almost all of us have DB-1 column handy. That's why I suggested this phase as sufficient for intended use.
When the list of compounds grew to a number it was natural to suggest better suited phase.
Cheers
Posted: Mon Jan 28, 2013 6:20 pm
by chromatographer1
yes, it is amazing how the question will evolve during the discussion so your adequate answer initially will suddenly be inadequate, and both the poster and you the responder will have wasted a lot of time and effort.
Please all who seek answers, give more information about your problem and try not to waste both yours and others time.
