Edwards E2M30
Posted: Sun Jan 27, 2013 8:08 am
Hi all,
i have just finished refurbishing an E2M30 Edwards pump ( i changed the blade kit and the clean and overhaul kit). I let it purge for some minutes and when i measured the vacuun it was 3,2x10-3 mbar which is extremely good. After a couple of hours it was 1.5x10-1, i opened the gas ballast valve for 15 minutes and it dropped to 3,4x10-3 mbars. 3hours later the external temperature of the pump was extremely high and the oil colour turned grey. I checked the blades, measured the distance to the rotors but it was good (0,07mm). I used a new bottle of oil from a different firm (ultra grade 19 but not Edwards) since i thought that maybe there was an issue with this lot of Edwards oil i had in my stock, but i still have the same problem. I would appreciate your help in this.
Derick
Derick
