Agilent 6890 insulation
Posted: Thu Jan 24, 2013 9:04 am
by tsoukalas1
I need to remove the back split/splitless injector from a 6890 Agilent GC and reinstall it on an other 6890 GC.
But yet, in my first GC, i have a hole without insulation inside. I don't want to reinstall an other injector, i just want to fill up the hole.
Anyone know a reference of agilent insulation? or wich material use agilent for insulation and i will try to fill up the hole myself.
I don't find the reference in my Agilent catalogue...
Thanks for your help
Pierre
Re: Agilent 6890 insulation
Posted: Thu Jan 24, 2013 3:06 pm
by KM-USA
In 2004 I "inherited" from Manufacturing a 5890 GC which had its FID and top insulation contaminated by oil in the air line that had been plumbed to the FID (that's another story).
Anyway, I cut out the oil-soaked insulation (which smelled real bad as the oven got over 190C) and filled the gaps with insulated fiberglass cloth tape, like 1 inch wide. I used Fisher #01-472A, but I didn't check if that part number is still "live", but that product should be available.
Posted: Thu Jan 24, 2013 3:33 pm
by Yama001
I usually use glass wool when I need instrument insulation - it is usually around the lab somewhere - prep labs often use it for filtering, etc.
Posted: Thu Jan 24, 2013 3:44 pm
by Peter Apps
You can get ceramic wool from RS components online, either sheets or loose fluffy bits.
Posted: Fri Jan 25, 2013 12:12 am
by KM-USA
Amazing what this genetic engineering can do to sheep....
Posted: Fri Jan 25, 2013 7:32 am
by tsoukalas1
Thanks a lot for yours answer.
I will buy ceramic whool and fill up the inlet hole.
Have a good day!
Pierre
Posted: Fri Jan 25, 2013 9:29 am
by dblux_
Ha, ha, ha ... excellent.
Posted: Fri Jan 25, 2013 10:26 am
by Johnny Rod
It stops them shrinking in rainy weather
probably
Posted: Fri Jan 25, 2013 2:48 pm
by gcguy
Glass wool sounds like a great idea. However a lot of "scientific " glass wool suppliers have now uprated the associated hazards statement concerning inhalation risk. The split insulation set is not overly expensive so I would imagine that the non-hole version will be cheap.
GCguy
