Empower 3 - Dot and Comma for decimals problem
Posted: Tue Jan 22, 2013 1:06 pm
At our laboratory we have two clients running empower.
At one of the clients, if you try to enter a decimal using the "dot" on the numpad, Empower does not recognize the next digit as a decimal.
The Windows 7 keyboard settings look the same to me for both systems.
We used to have this problem before on the other system. A support engineer fixed it, and I only remember it was a quite easy setting in Windows.
Does anyone know which setting I need to alter?
Thanks in advance
Thanks in advance
