Agilent 1100 injector problems
Posted: Mon Jan 21, 2013 8:52 pm
When my system's injector is on mainpass mode, there is a leak on the needle seat and the pressure fluctuates during the injection process and the run pressures are low. Peaks are broad and injection spike occurs at 6 minutes.
On bypass mode, the leak stops with normal run pressure and peak shape. When the instrument runs with ADVR checked, the problems are resolved. I just installed a new needle seat, and I am still seeing the problems. I looked at the rotor/stator and they appear to be intact and clean. The system was PM’d 5 months ago with a new rotor and stator. We are getting by with ADVR mode; however, I’m concerned that we will have problems with carryover in the long term.
Can someone offer a suggestion to fix the problem or further troubleshoot this?
Denise
Denise
