Problem with SCD help needed
Posted: Fri Jan 18, 2013 1:34 pm
Dears!
This is a problem i'm facing for a long period of time: my SCDs show terribly unstable results, from run to run the signal either rises or falls although i inject the same gas or liquid, at the same conditions.
To be precise, I have three Agilent 7890A instruments with two channels on each, one for gas injection, another for liquid injection. So, there are SIX SCDs on three instruments. All the gas flows (Hydrogen and air as oxydizer) are EPC controlled and controlled by Dual Plasma Controller. And once all six SCDs started giving different result on the same gas or on the same liquid from run to run... There is no changes in retention times but there is a great difference in signal heights...
I would be grateful to any reply, please, who has an experience of working with SCDs?
