Hi all,
Thanks for reading this post.
I am preparing a report style using in Agilent HPLC 1100 Chemstation. In the report layout, there is a built-in function called "Set Up Expected Ret. time (main peak) that should be supposed to show library retention time of particular compound.
However, in the printed report, field that should be showing the retention time is blanked for all compounds, for matched and unmatched compound. I can't figure out the reason behind. Does anyone have similar problem or get solution?
