Automatically turning Agilent 1100/1200 off after sequnce
Posted: Sat Jan 12, 2013 12:19 am
by CLSgroup
This is probably something very simple but I cant seem to find it in the manual. How do I set up my aqusition method to end after my run has ended. Do you have to create a special stop method? Using Agilent 1200.
Re: Automatically turning Agilent 1100/1200 off after sequnc
Posted: Sat Jan 12, 2013 7:13 pm
by akthmps
Under "sequence parameters", you can select for a macros to automatically run at the end of your sequence. Select the "shutdown" macros to turn off the components of your system.
Posted: Sun Jan 13, 2013 5:19 am
by Consumer Products Guy
Yeah. Choose Standby to shut off all, or PUMPall, or LAMPall.
