Strange peak in LC/MS
Posted: Thu Jan 10, 2013 10:13 am
Hi there!
I've conducted my senior internship in the Academic Hospital of Maastricht Netherlands. My project is about the identification of hemoglobin variants with LC/MS or LC/MS/MS. Everything went good so far but since November 29th I've a problem.
When I measure blanks, I get a strange peak which elutes at 15 minutes. When I analyze this peak, I mainly receive two m/z values which are 253.1 and 505.0.
HPLC: HP 1100 Series
Column: Zorbax C-18 at 35 Celcius with a C-8 guard column
Flow: 0.2 ml/min
Mobile phase: A - 2mM Ammoniumacetate 0.1% FA
B - Acetonitril 0.1% FA
Gradient: 0-15 min 40%A 60%B
15-16 min 40%A 60%B
16-17 min 98%A 2%B
17-25 min 98%A 2%B
MS: Agilent 6410 QQQ on full-scan because I'm still optimizing my method
It seems that the problem is the MQ water and I changed all mobile phases to ULC/MS water and the peak disappears but now it's back again..
Anyone suggestions
Flow: 0.2 ml/min
15-16 min 40%A 60%B
16-17 min 98%A 2%B
17-25 min 98%A 2%B
Anyone suggestions
