Types of column nuts for GC notched/not notched
Posted: Wed Jan 09, 2013 2:07 pm
by MSCHemist
I have a quick question on the capillary column nuts and ferrules. I have two types of column nuts. I have simple hedagonal wrench flat one that I use on the inlets for all my GC's and then I have one that has two wrench flats separated by a round valley in between them. I have that attached to my FID inlet on my 5890 with a 5181-3323 graphite vespel ferrule. Is that correct?
I have yet another that has a notch through the wrench flats.
What are the differences and what are each used for?
Re: Types of column nuts for GC notched/not notched
Posted: Wed Jan 09, 2013 3:01 pm
by MSCHemist
nevermind Agilent says the regular one is for short ferrules and the notched ones are for long ferrules like the graphite vespel ones used for MSD.
Posted: Thu Jan 10, 2013 7:18 am
by dblux_
BTW - Restek equivalent for use with short Agilent-style ferrules is notched (P/N 2184), and the other type for use with standard 1/16" ferrules is not notched (P/N 20883).
Posted: Thu Jan 10, 2013 1:39 pm
by Bigbear
Be carefull. We have had nothing but bad luck mixing ferrules and nuts from different suppliers. Match like to like, IE if using Agilent use all Agilent..
Posted: Thu Jan 10, 2013 4:30 pm
by dblux_
Impossible if have to buy in tender procedures. Lowest price wins.
Even if you specify Agilent catalog part number, phrase "or equivalent" must accompany. That's a law of tenders. Luckily non Agilent parts must be really equivalent to Agilent items. And as such Restek always describes them as equivalents in catalogue. So far I have no (serious) reasons to comply.
