Doxycycline method
Posted: Thu Dec 20, 2012 12:34 pm
I am trying to develop a more simplistic HPLC analysis method for doxycycline than the one described in the USP.
I found this post: viewtopic.php?f=1&t=2155&hilit=doxycycline
Changed it to:
Mobile phase composition: 80 0.02M KH2PO4 adjusted to pH 2.5 with H3PO4 + 20 ACN. (Isocratic)
Injection vol: 10 ul at 1 ml/min
Column: Symmetry shield RP18 3.9 x 15 mm 5um
wavelength: 355 nm
RT doxycycline = 8.4 min
Like tlili I get the analyte peak. But after the injection point the baseline slopes upward until the analyte peak. After the analyte peak the baseline is back to zero.
(see image: https://docs.google.com/open?id=0B57F_5 ... lJSWlNiSG8)
What is causing this phenomena and how do I prevent it?
Changed it to:
wavelength: 355 nm
